[Giveaway]Amigabit PowerBooster V3.2.4 1 PC / 1 Year
[Image: 7f851afc9f05.png]
Amigabit PowerBooster is PC maintenance software to maintain optimum performance so it can support all of our activities.
Each PC will experience performance degradation due to duration of the use. Lots of junk files that are remnants of the various applications and data that are not used anymore. This must be cleaned so that the PC performance back to optimal point. You can use Amigabit PowerBooster to do it.
Amigabit PowerBooster tools such as:
  • 360 Care
  • Driver Backup
  • Protect Privacy
  • Memory Manager
  • Startup Manager
  • Uninstall Manager
  • Process Manager
  • Shutdown Scheduler
  • Disk Defragmenter
  • Disk Cleaner
  • Disk Check
  • Registry Cleaner
  • Registry Defrag
  • Context Menu Fixer
  • Shortcut Cleaner
  • Undelete Deleted Files
  • Unlock Locked Files
  • File Shredder
  • File Encryption
  • Cloned File Finder
  • File Splitter
  • Empty Folder Finder
  • Top File Finder
  • Turbo Boost
Website
Promo
Note:
  • You have to install and activate it (please connect to internet to register) before the Giveaway offer for the software is over.
  • No free upgrades and technical support (Includes offline registration) will be provided for Giveaway Products.
the offer ends after 33 hours
[-] The following 1 user says Thank You to hanso for this post:
  • Jun
Paint.NET 5.1.12
Changes in 5.1.12:...harlan4096 — 08:16
Master PDF Editor Updates Thread
Latest build is Mast...jasonX — 05:14
K-Lite Codec Pack 19.5.5 / 19.5.7 Update
Changes in 19.5.5:...harlan4096 — 17:24
NanaZip 6.0 Update 2 (6.0.1650.0)
NanaZip 6.0 Update...harlan4096 — 17:18
PrivaZer 4.0.119
PrivaZer 4.0.119 ...harlan4096 — 17:16
avatar (40)ebenofit
avatar (45)walllMIZ
avatar (41)oconyho
